It is currently Mon Aug 18, 2025 1:56 pm
PostPosted: Thu Aug 13, 2009 2:06 pm
Last Name: Kitchen
State: SW Pa
Hi Guys! I haven't been in for 2 weeks for the most part. I remodeled the Dining room. Even cleaned the windows! Back to guitars!
I haven't looked in the land of misinformation. I would rather get a recomendation here.
I have a Ridgid 14". I would like to cut billets with it. I am self taught and new to Bandsaws.
I was cutting a rock last night. I mean Maple :) Trying to make a slab big enough for a large Archtop Pickguard. Geeze! This was the first time I have asked a chore of this saw. The bottom rubber was slipping. The blade was slipping..... I have the manual and can work the basics. I tried the wheel adjustments back and forth and tracking and and and ......but I am missing something. So far it's not any of my fingers.
I know I am a bit undersized for the billet chore but it what I got for now. I'd love a video or a truck load of pictures on how to maximize the use of this thing.
PostPosted: Thu Aug 13, 2009 2:25 pm
You'll find a lot of info in this book:
http://www.amazon.com/New-Complete-Guide-Band-Saw/dp/1565233182/ref=sr_1_2?ie=UTF8&s=books&qid=1250191474&sr=1-2.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Thu Aug 13, 2009 4:08 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
What blade were you using? For resawing thick stock, a 1/2" 3TPI (teeth per inch) or variable 3-4TPI blade has
been the best for me on my 14". Closely set teeth don't have very large gullets, and the gullets fill with sawdust
before the teeth clear the bottom of the workpiece. Causes excess friction, burning, slow cutting, wandering of
the blade. A lot of people, myself included, like the Woodslicer from Highland Hardware, but there are other good
ones from other suppliers.
Gene
PostPosted: Thu Aug 13, 2009 9:12 pm
I use a 1/2" Woodslicer on my Grizzly 14". I can cut cleaner and thinner with it than with other regular blades I've tried. I have not tried a carbide tipped blade though.
PostPosted: Thu Aug 13, 2009 10:00 pm
"Band Saw Handbook" is another good shop reference.
Tom Krebs
PostPosted: Fri Aug 14, 2009 7:18 am
Last Name: Kitchen
State: SW Pa
http://www.youtube.com/watch?v=toNsPh-pxgc
I"ll check out the books and learn more about the blades. I would prefer a video though. I did find this one on operating a table saw. :D
PostPosted: Fri Aug 14, 2009 11:38 pm
Last Name: Shaw
City: Philadelphia
I have an older version of the book Laurent Brondel recomends. Great book. I recomend it to...Mike
PostPosted: Fri Aug 14, 2009 11:44 pm
Last Name: Shaw
City: Philadelphia
First the blade tension has to be proper for your blade size. Second you need to adjust the tracking. Then 3rd you need to adjust the upper and lower guide bearings and thrust bearings. They all have to be alligned properly to the blade. If not set properly the blade will not track very well and it won't cut well at all.
PostPosted: Sat Aug 15, 2009 10:05 am
First name: Chuck
Last Name: Hutchison
City: Houston
Howdy YJ John,
Here is a link to a video that Grant Goltz made. He's over on the Luthier's Community. Although he is using a 20" Grizzly and not a 14" there still is a lot of good info here.
Here is the link.
http://www.luthiercom.org/phpBB3/viewtopic.php?f=56&t=113
PostPosted: Sat Aug 15, 2009 5:39 pm
Like everyone else has said, go through your bandsaw and align, square and tweak everything as good as you can. It all helps.
Has anyone mentioned the catalog from Iturra Design - lots of information in there, he actually has a bunch of small articles in there and he sells some good products too. I put in one of his tension springs in my 14" Grizzly and it made a noticeable improvement in tracking when resawing. The original spring was just too weak. They're in Jacksonville Fl and you can call them at 866-883-8064.
PostPosted: Sat Aug 15, 2009 9:23 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
hi guys
i found the exact same type of model as a grizzly 12" in a old yard
its missing the rectangular piece which holds the blade at the top of the throat
could anyone inform me what the piece is called ?
ive been googling around looking for parts for days....... so much so that
i would make the dam thing in the time ive spent
thanks again tomas
PostPosted: Sat Aug 15, 2009 11:32 pm
I have that saw, with a riser block. Works OK, the key is not to feed any faster than the saw can consume without excess laboring. On a block like that, it will be just barely perceptable that you are making any progress, but slowly you will get through it.
Users browsing this forum: DennisK and 14 guests
